A Battery of Artillery GB Entries
Page 1 of 3 1, 2, 3  Next
Post  S P Hammerton on Sat Jul 23, 2011 2:21 pm
Hi Folks
Having established what's happening, I'll kick off with the first entry.
Trumpeter 8.8cm PAK43 Anti-Tank Gun
Revell/Zvezda L4500R Maultier Half-Track
Both will be built pretty much OOB, with any DIY improvements as neccesary.
There will almost certainly be some crew to make the scene look busy, as well as ammo crates and the usual debris found around big field pieces.
Re: A Battery of Artillery GB Entries
Post  John T on Sat Jul 23, 2011 3:56 pm
Hi Simon
In the rules you say open-topped Self Propelled. So then the RSO tractor mounting a 7.5cm pak 40 would be okay?
Post  S P Hammerton on Sat Jul 23, 2011 4:26 pm
Hi John
Absolutely fine. The idea is to showcase the actual artillery pieces, which is why enclosed guns such as M109 and PzH2000 are a no-no.
Post  John T on Sat Jul 23, 2011 5:25 pm
Thanks mate.
Post  Jenny Ryan on Sat Jul 23, 2011 5:46 pm
Well I will build a Sd.Kfz 7 towing a 150mm cannon cheers . I will keep aftermarket to a minimum for this build Very Happy !
Post  reconron on Sat Jul 23, 2011 5:50 pm
S P Hammerton wrote:Hi Folks
Sweet!!!I really looking forward to that PAK43!
Is the Maultier the towing vehicle for the PAK?Seems strong enough to do the job!
Greetings,Ron.
reconron
Post  S P Hammerton on Sat Jul 23, 2011 6:00 pm
Hi Ron
I've seen images of the L4500R towing the PAK43, 43/41, LeFh18, as well as numerous Flak weapons.
Roll on October 1st.
Post  reconron on Sat Jul 23, 2011 6:04 pm
Jenny Ryan wrote:Well I will build a Sd.Kfz 7 towing a 150mm cannon cheers . I will keep aftermarket to a minimum for this build Very Happy !
I toke a ride in the Sd.Kfz 7 [late version] just last May.
Maybe you could use this as reference?[if you like to].
http://tanksandthings.niceboard.org/t4358-militracks-2011-overloon#49368
Greetings,Ron.
reconron
Post  Jaymes Crowther on Sat Jul 23, 2011 9:47 pm
Simon would an Archer be Ok?
Jaymes
DISLECKIC AND PRUOD OF IT
Jaymes Crowther
Post  S P Hammerton on Sat Jul 23, 2011 10:03 pm
Hi Jaymes
Absolutely, although you may want to talk to Glyn Spur, he's still recovering. Very Happy
Post  Jaymes Crowther on Sat Jul 23, 2011 10:28 pm
LOL failing that, I'll super detail an Israeli M107/110 I'll have to find where he's pestering lately
Jaymes
Jaymes Crowther
Post  S P Hammerton on Sat Jul 23, 2011 10:42 pm
As they used to say in the Amex adverts...
That'll do nicely. Very Happy
Oct. build entry
Post  mikec on Sun Jul 24, 2011 2:14 am
Greetings Guys, and Gals;
..... I reckon, ..... I will list my entry at this time.
Trumpeter's.......... 17cm Kanone...... in a open toped fortification.
I haven't decided which campaign, West, or East. More than likely
the Western Front.
This one should be fun..........
Mike
mikec
Post  S P Hammerton on Sun Jul 24, 2011 3:57 am
Hi Mike
Nice choice. That's the one with the double recoil system isn't it?
17cm K-18
Post  mikec on Sun Jul 24, 2011 4:33 am
S P Hammerton wrote:Hi Mike
Hi Simon;
...... Yes it is, it is a rather nice set up. The gun has the normal recoil cylinders, and the upper
receiver slides back, like the upper receiver on a 1911/A1 automatic. I have read...... after firing
a round, the gun does not move any.
Photo..... Bundesarchiv, Germany........ Photo...... Frank........ Feb. 1944.
Later,
Mike
mikec
Post  Andy J on Sun Jul 24, 2011 4:27 pm
Rocket/missile artillery still included in this GB? If they are then I'll still like to go ahead with my Rheintochter, it's the Cromwell kit with the missile mounted on a cut down Flak 37 mounting.
If it's only tube artillery then I have a few possibilities from my stash (from memory as they're all boxed up in anticipation of moving)
17 cm Kanone auf Tiger B
M40 GMC
M10 17 pdr Achilles
Sturer Emil
Dicker Max
K5 Eisenbahngeschutz
Or of course I could treat myself and go for a 25 pdr Very Happy
Post  S P Hammerton on Sun Jul 24, 2011 5:12 pm
Hi Andy
Rockets/Missiles are more than welcome.
I'd love to see one of these built.
Post  Andy J on Sun Jul 24, 2011 5:22 pm
S P Hammerton wrote:Hi Andy
Cool! A missile to lob at the wingy thingies it is then Laughing
Post  G Cooper on Thu Jul 28, 2011 1:25 am
What a Face
I am going to finally be able to start building things and stuff again, so I have just gotta get into some of these group builds again. Cause I never pass up an opportunity to start something new all over again Suspect .
I will be attempting to do one of the rare little critters that the Germans put together as a kind of kobble pot construction. I think that the official name for this vehicle was the "Jenny's Pander" What a Face , but unofficially it was called the "5cm PaK 38 L/60 auf Fahrgestell Panzerkampfwagen II (Sf)" Suspect
It really shouldn't be all that hard, as I got a big box of sticks and rocks and things like that to make it out of tongue
Post  S P Hammerton on Thu Jul 28, 2011 1:47 am
Hi Gary
Can't wait to see it.
If you run out of rocks, I've got 100 metres of Cornish Granite you can use.
It's 3 metres high at its lowest point, going to 6 at its highest. My place is on the side of a hill, hence the difference.
My house is surrounded by the stuff. It's hundreds of years old and you couldn't get through it with a nuke. Twisted Evil
Post  G Cooper on Thu Jul 28, 2011 1:58 am
S P Hammerton wrote:Hi Gary
Hiya Simon:
Well Suspect , Maybe if you save some of your money you could afford to get a house that isn't so old Shocked . But at least you will be safe if someone launches a nuke at you Razz
lol! lol! lol!
Post  S P Hammerton on Thu Jul 28, 2011 3:09 am
The damn thing's got a preservation order on it, the insurance on it is insane as it would cost £100,000 to rebuild it.
It's about 1 to 1.5 metres thick. I'm thinking about getting a couple of siege catapults to honk off the neighbours. Very Happy
Post  The Zod on Mon Aug 08, 2011 3:14 am
Let's see........................ I have the older testors/Italeri M110.But I really hate Italeri tracks. Evil or Very Mad I bought an older Testors/Italeri Katusha rocket launcher on Ebay for a real good price. I don't think the truck it is monted on is a W.W.2 version though.
Post  S P Hammerton on Mon Aug 08, 2011 9:54 am
Hi Chad
The GB is not time-specific, so any historical period is fine.
I'm hoping someone is going to put up a trebouchet, or siege catapult. Shocked
Post  Jenny Ryan on Mon Aug 08, 2011 12:25 pm
S P Hammerton wrote:Hi Chad
What ? From your childhood ? lol! lol! lol! lol! lol!
