Dealing with warped resin parts
Post  sharkmouth on Thu Apr 09, 2009 6:46 pm
Many times a kit which has been stored will become warped. Whether at the stockist or in your stash, pressure or temperature may cause thin long items to warp.
Here are some thin resin Panzer 38 (t) sprockets that were deformed during shipment. The inset shows them after a dip.
The technique is simple and based on the principle that resin has memory. If the manufacturer allowed the resin to fully cure in a true and level mold, the resin will return to the shape it had in the mold if given the opportunity.
I usually boil water and put it into a clear container so I can see the effect of the heat. Here I am using a Pyrex measuring cup as my normal coffee press jar is too unsightly Wink
Note that one must hold the item by the carrier sprue. In the case above, this was not a good idea as the warmed up resin sprocket began to deform from the weight of the water. I had to hold one of the fins between the sprockets and re dip it.
The idea is to dip the item into the water slowly and watch it relax into the proper shape. This means that the item can not touch any of the sides or bottom.
After the proper shape is regained, slowly remove the item from the hot water and dip into cold water. After it is in the cold water, it can be placed onto a towel to air dry.
Here we have Tank Work Shop's British Style Wading Kit as it came out of the package. I did NOT remove the casting blocks and used them as a handle to dip them into the hot water.
Post dip, note the water droplets still on it:
Here is a severely warped Marder II interior:
I took the video but it is a bit out of focus. Funny thing is, the water was a bit too hot so the resin was fluttering inside the container as my hands shook (I'm 84 years old on film).
As you can see, I dipped it twice since I removed it too fast during the first one.
This has worked on EVERY warped item I have except for an Eastern European one which I suspect was warped in the mold. I have straightened out items as delicate as the above to thicker hulls (which warped under pressure).
The bottom line is to NOT touch, push, prod, the piece and allow it to regain the original shape on its own. Believe me, it's memory is a lot better than you can do when it comes to straightening out gun barrels!
I hope this quick tip is of help.
Saúl García
Re: Dealing with warped resin parts
Post  eatcrow2 on Thu Apr 09, 2009 8:36 pm
Hi Saúl... Great tip, and some good photos showing the "before and after" results..
Cheers..
P.Crow
eatcrow2
Location Location : Santa Monica, Calif.
http://www.picturetrail.com/members/edit
Post  Kreighshoer on Tue Apr 14, 2009 12:57 pm
and since i just have followed your tip i was able to rectify a badly warped piece of resin for my marder dio! thank you saúl! thank you very very much! bounce
you are the nicest sharkmouth out there in the world man! Wink
Post  Jenny Ryan on Tue Apr 14, 2009 2:08 pm
Well that is really cool information Saul Very Happy , thanks for posting it !
